It is quite common for me to cut a design to extract a vertical transition, e.g. Layer1-to-Layer6, to understand crosstalk, return loss, etc. When working with many nets, assigning the ports takes 80-90% of the process. I'm trying to find a way to do this with PyAnsys.
I'm using a Hfss3dLayout object to get the nets and lines of a net, however, I haven't found a good way to assign the lumped port to the edge of the trace.
Any help would be appreciated.
Thanks.
