Hello everyone,
I am facing an interesting issue in Fluent Meshing 2024R1 standalone for CFD purpose. I use it on Windows and Linux (HPC) os, thus I launch Fluent in batch mode and I feed it with a journal that contains TUI commands.
In the batch script, I define the directory that contains the batch script AND the journal as the working directory. However, when I import the geometry prior meshing, which is a CAD file located in a different directory, the WD changes. My problem is that I know the absolute path for geometry_directory but I do not know the absolute path to the simulation_directory in general, and I may have many of them.
I describe the tree structure and my files below:
Root
├── simulation_directory
│ └── journal.jou
│ └── batch_script.sh
├── geometry_directory
│ └── geo_file.pmdb
Batch script:
module load fluent/24.1
cd $SLURM_SUBMIT_DIR
# Run application
fluent 3ddp -t$SLURM_NTASKS -g -cnf=hostsfile_job_$SLURM_JOBID.txt -i journal.jou
-meshing
Journal:
;; Here WD = Root/simulation_directory
(%py-exec “"workflow.TaskObject['Import Geometry'].Arguments.set_state({r'FileName': r'/Root/geometry_directory_geo_file.pmdb',r'ImportCadPreferences': {r'MaxFacetLength': 0,},r'LengthUnit': r'mm',})")
(%py-exec "workflow.TaskObject['Import Geometry'].Execute()")
(newline)
;; Now WD = Root/geometry_directory
I tried several things, they did not work, and I could only find workarounds that imply the absolute path of the simulation folder, which I do not want. If someone has a fix for preventing Fluent from changing the WD, I would take it with pleasure.
Best,
Alexandre G.
