I'm running codes in VS code tool. need to setup, Harmonic environment to modal. Below code is using to setup harmonic environment analysis after modal run. Help me to set up Harmonic environment to modal
Script_harmonic = """
harmonic_analysis = Model.AddHarmonicResponseAnalysis()
analysis_settings = harmonic_analysis.AnalysisSettings
analysis_settings.RangeMinimum = Quantity(10, "Hz")
analysis_settings.RangeMaximum = Quantity(1000, "Hz")
analysis_settings.SolutionIntervals = 100
analysis_settings.ClusterResults = True
mechanical.run_python_script(Script_harmonic)
