In Fluent 2020 R2, the following command worked correctly:
solve/execute-commands/add-edit command-101 40 "iteration" "report/system/sys-stats"
However, in Fluent 2025 R2, the command no longer works.
Error message:
solve/execute-commands/add-edit command-101 Adding command-101
Error: api-set-var: the object is not active
Error Object: "solution/calculation-activity/execute-commands/command-101/execution_type"
I asked AnsysGPT and tried its suggestions, but I couldn’t resolve the issue. I’m new to using these commands and not yet very familiar with Fluent, so I would appreciate any information or references that could help.
