Hi Guys,
First of all a happy new you to all of you!
I just stumpled across some weird behavior of MI, but I'm not absolutely sure whether to blame MI oder STK for it =D
Let's have some long text attribut containing just a line break without anything else. It'll will look pretty inconspicuous in MI Viewer:
However, STK seems to parse that almost empty value to a "" instead of a "\n". But it doesn't set rec.is_empty() to true.
I wouldn't care about it if this would'n cause an error 500 upon import:
(attribute "Tradenames" of record "Alumino silicate - 1720" populated with a single blank)
db = mi.get_db("MI Training")
tb = db.get_table(name="MaterialUniverse")
rec = tb.get_record_by_id(hguid="ba22491d-b470-42cf-80d7-531ff81b1583")
tb.bulk_fetch(records=[rec], attributes=["Tradenames"], parallelize=True)
# Try to write the record without changes
rec.set_attributes([rec.attributes["Tradenames"]])
mi.update([rec])
DataImport_SetRecordAttributes failed with code 500 and message: Bad Request
It seems like it makes no difference whether the value is a single blank (" ") or a line break.
With STXT attributes, the behavior is similar but limited to blank, as one can't enter a line break in them. On the other hand, they're completely invisible in Viewer
I'm unsure whether I'd be happier with MI Viewer ignoring such a single character when clicking on "save" or STK parsing it correctly. And I admit that this is for sure nothing that's likely to happen often. However, maybe you guys have some possibility to adress it.
Best
Daniel
