Hi people,
I am trying to expand a field with only 1 value on one node from the min_max operator. To the same scoping of FieldA.
def ones_like(field):
"""Creates a field with values 1 scoped over the original field"""
zeros = scale(field, 0.0)
ones = ops.math.add_constant(zeros, 1.0)
return ones.outputs.getfield()
def scale(field, factor):
op = ops.math.scale()
op.inputs.field.Connect(field)
op.inputs.weights.Connect(factor)
return op.outputs.getfield()
min_max_op = ops.min_max.min_max()
min_max_op.inputs.field.Connect(FieldA)
Field_min = min_max_op.outputs.getfield_min()
Field_scaled = scale(ones_like(FieldA), Field_min)
Does someone know how to make a field with only 1 value and the right scoping?
Or how to convert a field to a scalar?
Kind Regards,
Thomas25
