Currently have a two piece model.
Base "table" piece that is rigid and has been modeled as such
Bracket piece that is attached to the base structure and is to be assed for forces and how it reacts/stress
Current have contact surfaces as shown in images below between the hooks on the bracket which connect to the studs on the table as no separation as well as the bottom side of the bracket and the top surface of the table. This is the only way I can get a solution to solve without have a convergence issue. Also note the force which is on the bracket top surface and parallel to that surface. How should I model these contact surfaces?
This forum is dedicated to scripting. For any other question, use this other forum:
Ansys Learning Forum
