This is for transferring LS-DYNA results (dynain ASCII file format) into Static Structural, via an External Model system. The effective plastic strain (EPS) data in dynain may be incompatible with the material model used in Static Structural. Zeroing EPS can fix errors associated with this, and means that only the stress tensor is transferred.
