I want to create an ACT Result Object with the Scoping set to a Construction Geometry Surface.
Basically it should mimic the built-in Surface Result functionality, but I want to be able to map user created data (from scripting) to the cross section surface.
It could be a Python Result object, or an ACT extension, or even the built-in Surface Result object if there is a way to manipulate the data.
