I am simulating the impact behavior of high-strength material using Ansys Explicit Dynamics with the Johnson-Cook model.
I have observed a strange numerical phenomenon:
When Reference Strain Rate = 0.001s^-1: The simulation results show purely linear elastic behavior. Even when the stress exceeds 10,000 MPa, the Equivalent Plastic Strain remains 0. This is physically incorrect, as the calculated dynamic yield stress should be well below 2,000 MPa.
When Reference Strain Rate = 0.01s^-1: The simulation works perfectly. The material exhibits clear plastic deformation, and the results align with physical expectations.
To isolate the issue, I conducted a parameter sweep for the Reference Strain Rate ranging from 0.0001 to 1000. A distinct "watershed" phenomenon was observed between 0.001 to 0.01
WHY?
