How to sum up HGENRATE NMISC 39 (SOLID278/Thermal) using Mechanical scripting?
The below script does that for all steps and elements: APDL way:
SET,LAST,LAST ! set last result ETABLE,mynmisc39, NMISC, 39 ! get nmisc39 SSUM ! sum *GET,my_sum,SSUM,,ITEM,mynmisc39 ! get sum as my_sum
Mech. Script way
analysis = ExtAPI.DataModel.AnalysisList[0] # Get result reader reader = analysis.GetResultsData() # Get global mesh data (contains element IDs) mesh = analysis.MeshData # or MeshDataByName("Global") if preferred elemIds = mesh.ElementIds # list/array of element IDs nElems = len(elemIds) # total element count # Example: retrieve stress result "S" as an elemental result datasets = reader.ListTimeFreq #Loop over results for i in range(len(datasets)): reader.CurrentTimeFreq = reader.ListTimeFreq[i] #Here is where time is selected rs = reader.GetResult("NMISC39") sValues = rs.GetElementValues(elemIds, False) totw=0 # Loop over elements with index controlled by nElems for e in range(nElems): eid = elemIds[e] totw=totw+sValues[e] print(str(totw) + " , " + str(i))
