Dear support,
I am trying to access to the graphics methods to create scenes, display geometries and mesh elements in order to visualize the mesh in Fluent meshing mode. So far I can only use the tui commands like:
# Reset to default
session.execute_tui('/display/views/default-view')
# Fit geometry
session.execute_tui("/display/views/auto-scale")
# Set view
session.execute_tui("/display/views/camera/position 3952.114 2264.67 1672.573")
session.execute_tui("/display/views/camera/target 145.3241 918.1475 50.35107")
session.execute_tui("/display/views/camera/up-vector -0.338645 -0.1597314 0.9272673")
session.execute_tui("/display/views/camera/zoom 1")
session.execute_tui("/display/views/camera/projection orthographic") # orthographic || perspective
However in solver mode it is way more intuitive to set camera properties and create graphics using methods like the ones below:
# Get the session views
session_views = session.settings.results.graphics.views
# Reset it to default
session_views.reset_to_default_view()
# Set a desired camera view
session_views.camera.position(xyz=[0.15,0.45,-1])
session_views.camera.target(xyz=[0.15,0,0])
session_views.camera.up_vector(xyz=[0,0.9,0.4])
session_views.camera.zoom(factor=1.0) # Need to reset the view because the zoom is relative to the current view
session_views.camera.projection(type='orthographic') # orthographic || perspective
# Save view
session_views.save_view(view_name='view_cut_planes')
# Restore view
session_views.restore_view(view_name='view_cut_planes')
Is it possible to create graphic visualizations in meshing mode in the same way as in solving mode? I haven't found the method for it yet and any guidance would be very appreciated.
