Do you know if there is a way to select edges shared between shell bodies ? (In order to put them in a named selection)
In Mechanical, there a display option to see all the share edges. But can we "extract" this data ?
Regards, Jean
Hello @Jean
You can use Named Selection Worksheet option and use "Shared Across Bodies" option as a filter criteria to extract shared edges for example. In the below picture,
