I am in the process of replacing the legacy ansys-internal/solution-applications-actions by the (recommended one in its doc) ansys/actions/tests-pytest action.
Has anyone done it in a SAF based solution CI pipeline?
If so, could you please share a link to or paste an example of a Github workflow using the pyansys action to run unit tests of a SAF based solution in its CI pipeline?
Thank you in advance for your help!
BR/Lucas
