Map body force density on Mechanical Mesh
import os import numpy as np import ansys.dpf.core as dpf server = dpf.start_local_server(ansys_path=r"C:\Program Files\ANSYS Inc\v252") print(server) def read_lorentz_forces(fld_path: str): data = np.loadtxt(fld_path, skiprows=2) # shape (N, 6) coords = data[:, :3] # x, y, z forces = data[:, 3:] # fx, fy, fz n_nodes = data.shape[0] node_ids = list(range(1, n_nodes + 1)) # --- coordinates field --- coords_field = dpf.fields_factory.create_3d_vector_field( num_entities=n_nodes, location=dpf.locations.nodal, ) coords_field.scoping.ids = node_ids coords_field.data = coords coords_field.unit = "m" # source mesh source_mesh = dpf.MeshedRegion(num_nodes=len(coords_field.scoping.ids)) source_mesh.unit = coords_field.unit for nid in coords_field.scoping.ids: source_mesh.nodes.add_node(nid, coords_field.get_entity_data_by_id(nid)) # --- force density field --- force_density_field = dpf.fields_factory.create_3d_vector_field( num_entities=n_nodes, location=dpf.locations.nodal, ) force_density_field.scoping.ids = node_ids force_density_field.data = forces force_density_field.unit = "N/m^3" return coords_field, source_mesh, force_density_field wkdir = r"…" fld_file = r"…\lorentz_forces.fld" coords_field, source_mesh, force_density_field = read_lorentz_forces(fld_file) rst = r"…\file.rst" model = dpf.Model(rst) sm = source_mesh tm = model.metadata.meshed_region report_path = os.path.join(wkdir, "mapping_report.html") wf = dpf.Operator("mechanical_native_mapping::prepare::point_cloud") wf.connect(0, sm) wf.connect(1, tm) wf.connect(5, dpf.locations.nodal) wf.connect(6, 3) wf.connect(8, report_path) wf.connect(10, "triangulation") # optional, default is "triangulation" s_fc = dpf.FieldsContainer() s_fc.labels = ["time"] s_fc.add_field({'time' : 0}, force_density_field) native_mech_map = dpf.Operator("mechanical_native_mapping::apply") for index in range(5): native_mech_map.connect(index, wf, index) native_mech_map.connect(5, s_fc) native_mech_map_f = native_mech_map.eval()[0] # Get Lorentz forces lf = dpf.operators.geo.integrate_over_elements(field=native_mech_map_f, mesh=tm) # Total Lorentz force lf_sum = dpf.operators.math.accumulate(lf).eval() print(lf_sum) # Plot bfd tm.plot(native_mech_map_f)
