Another customer request: how to probe for all principal stresses at once? This can't be done using regular probes.
Not really a probe, but I suggest the following which will display a message box with the values of the principal stresses. It uses DPF.
import math import units import mech_dpf import Ans.DataProcessing as dpf clr.AddReference("Ans.UI.Toolkit.Base") clr.AddReference("Ans.UI.Toolkit") from Ansys.UI.Toolkit import * curSel=ExtAPI.SelectionManager.CurrentSelection # Need to have two faces selected, otherwise pass if (curSel.Ids.Count==0): mess_line1 = 'Please select at least one node' MessageBox.Show(mess_line1) pass meshData=ExtAPI.DataModel.Project.Model.Analyses[0].MeshData scoping=dpf.data.Scoping() scoping.Ids = curSel.Ids scoping.Location=dpf.enums.location.nodal an1=ExtAPI.DataModel.AnalysisByName(ExtAPI.DataModel.AnalysisNames[0]) rstFile=an1.WorkingDir+'file.rst' dataSource = dpf.data.DataSources(rstFile) stressOp1 = dpf.operators.result.stress_principal_1() stressOp2 = dpf.operators.result.stress_principal_2() stressOp3 = dpf.operators.result.stress_principal_3() stressOp1.inputs.data_sources.Connect(dataSource) stressOp2.inputs.data_sources.Connect(dataSource) stressOp3.inputs.data_sources.Connect(dataSource) stressOp1.inputs.mesh_scoping.Connect(scoping) stressOp2.inputs.mesh_scoping.Connect(scoping) stressOp3.inputs.mesh_scoping.Connect(scoping) stressData1=stressOp1.outputs.fields_container.GetData()[0] stressData2=stressOp2.outputs.fields_container.GetData()[0] stressData3=stressOp3.outputs.fields_container.GetData()[0] stressData=[] for nid in curSel.Ids: stressData.append([nid,stressData1.GetEntityDataById(nid)[0],stressData2.GetEntityDataById(nid)[0],stressData3.GetEntityDataById(nid)[0]]) # Display result mess_line='Node\tS1\tS2\tS3\n' for sd in stressData: mess_line+=str(sd[0])+'\t'+str(round(sd[1],2))+'\t'+str(round(sd[2],2))+'\t'+str(round(sd[3],2))+'\n' MessageBox.Show(mess_line)
