How to get current design-point folder from WB scripting console?
Ayush Kumar
Member, Moderator, Employee Posts: 489
import os result_files = filter(lambda x: ("ds.dat" in x), GetAllFiles()) all_design_point_paths = list(set([os.path.dirname(result_file) for result_file in result_files])) current_dp_name = Parameters.GetCurrentDesignPoint().DisplayText.replace(" ", "").lower() current_dp_path = filter(lambda x: (current_dp_name in x), all_design_point_paths)
2
