How to install the Granta STK in IronPython in Ansys?
There doesn't seem to be a way to just "pip install" something in IronPython. Is there a good way of installing packages, such as the Granta STK, in IronPython?
As an answer to the general question, most packages are available through easy_install.exe. This should be present in a plain installation of IronPython in the Scripts folder.
I had various issues with installing packages, the most common one was
TypeError: argument of type 'ZipFile' is not iterable
This is easily fixed by retrying the installation, which should succeed the second (or occasionally third) time.
I also had problems with dependency installation, in these cases I had to manually install the dependencies using easy_install (in my case this was traitlets, simplegeneric and scandir).
The documentation for IronPython claims that pip now works, as long as you invoke it like:
./ipy.exe -X:FullFrames -m pip install my_package
I was able to get it to download packages correctly, but they were not available for me in the interpreter. The only way I was able to use packages was with easy_install as above.
2
