How do I parse the content in Comments of Mechanical DataModelTree?
Ayush Kumar
Ayush Kumar Member, Moderator, Employee Posts: 497
I have to parse the contents in Mechanical DataModelTree Comment to retrieve and send the data in further down the chain in a customized workflow.
enter image description here
  • Ayush Kumar
    The comment object - Ansys.ACT.Automation.Mechanical.Comment uses HTML syntax to render data. So you can use standard IronPython library HTMLParser in the Mechanical Scripting Console.
    from HTMLParser import HTMLParser
    class MyHTMLParser(HTMLParser):
        def handle_starttag(self, tag, attrs):
            u"""
             Executed each time start tag is found.
            print "Encountered the beginning of a %s tag" % tag
        def handle_data(self, data):
            u"""
             Executed each time data is encountered.
            print "Encountered data - %s" % data
        def handle_endtag(self, tag):
            u"""
             Executed each time an endtag is found.
            print "Encountered the end of a %s tag" % tag
    The above mentioned class inherits from HTMLParser, you can define other functions in the class to extend the functionality of the parent class.
    Example usage:
    # Select a comment in the DataModelTree
    comment = Tree.FirstActiveObject
    html_parser = MyHTMLParser()
    html_parser.feed(comment.Text)
    Output:
    Encountered the beginning of a p tag
    Encountered data - This is sample text 1.
    Encountered the beginning of a br tag
    Encountered data - This is sample text 2.
    Encountered data - This is sample text 3.
    Encountered the end of a p tag
