Using ACT, how can I create a Worksheet named selection and add the faces included in a previously d
Pernelle Marone-Hitz
Using ACT, how can I create a Worksheet named selection and add the faces included in a previously defined named selection ?
Let's assume a first face named selection exists in the tree, named "FirstNS".
A second named selection can be inserted in the tree with:
Model=ExtAPI.DataModel.Project.Model SecondNS=Model.AddNamedSelection()
The name of the new named selection can be changed through:
SecondNS.Name="SecondNS through WS selection"
The scoping method can be changed from Geometry Selection to Worksheet:
SecondNS_WS=ExtAPI.SelectionManager.CreateSelectionInfo(SelectionTypeEnum.WorksheetSpecific) SecondNS.Location=SecondNS_WS
The criteria to create the new named selection can be changed using:
SecondNS.Location.AddRow() #Add new row SecondNS.Location.SetAction(0,NamedSelectionWorksheetAction.Add) # Set "Action" to "Add" SecondNS.Location.SetEntityType(0,NamedSelectionWorksheetEntityType.Face) # Set "Entity type" to "Face" SecondNS.Location.SetCriterion(0,NamedSelectionWorksheetCriterion.NamedSelection) # Set "Criterion" to "Named Selection" SecondNS.Location.SetOperator(0,NamedSelectionWorksheetOperator.Equal) # Set "Operator" to "Equal"
The "Value" can be set to "FirstNS" with the following code:
for NS in Model.NamedSelections.Children: if NS.Name == "FirstNS": SaveNS = NS SecondNS.Location.SetValue(0,SaveNS.Id)
The new named selection can be generated with:
SecondNS.Location.Generate()
For WB version 2020R2 and above:
Model = ExtAPI.DataModel.Project.Model second_ns = Model.AddNamedSelection() second_ns.Name = "Second NamedSelection through WS selection" second_ns.ScopingMethod = GeometryDefineByType.Worksheet Criteria = second_ns.GenerationCriteria Criteria.Add(None) Criteria[0].EntityType = SelectionType.GeoFace Criteria[0].Criterion = SelectionCriterionType.NamedSelection Criteria[0].Operator = SelectionOperatorType.Equal Criteria[0].Value = ExtAPI.DataModel.GetObjectsByName("first_ns")[0] second_ns .Generate() ExtAPI.DataModel.Tree.Refresh()
2
