How to extract unaveraged stresses at a node using DPF?
Rohith Patchigolla
Member, Moderator, Employee Posts: 249
How to extract unaveraged stresses at a node (at all elements the node shares) using DPF?
Below script shows how one could extract unaveraged component stresses (in this case stress Y) at a node. The values corresponding to all the elements connected to the input node id are printed at the end.
Note: This approach cannot be used for getting unaveraged principal/equivalent stresses, as the midside node stresses will be incorrectly computed.
##Unaveraged Nodal Stresses based on Node Id. import mech_dpf import Ans.DataProcessing as dpf mech_dpf.setExtAPI(ExtAPI) #Get the data source (i.e. result file) dataSource = mech_dpf.GetDataSources(0) #Enter the node ID nodeId = 100 #get Connected Elements mesh = dpf.operators.mesh.mesh_provider() mesh.inputs.data_sources.Connect(dataSource) node_connectivity = mesh.outputs.getmesh().NodalConnectivityPropertyField.GetEntityDataById(nodeId) #Create operator sy_op = dpf.operators.result.stress_Y() sy_op.inputs.data_sources.Connect(dataSource) sy_op.inputs.requested_location.Connect('ElementalNodal') sy_fields = sy_op.outputs.fields_container.GetData() sy_field = sy_fields[0] #Extend stress result also to mid side nodes mid_op = dpf.operators.averaging.extend_to_mid_nodes() mid_op.inputs.field.Connect(sy_field) sy_field_corner_mid = mid_op.outputs.field.GetData() print 'Number of elements connected to node',nodeId,'=',len(node_connectivity) for id in node_connectivity: elem_num = mesh.outputs.getmesh().ElementIds[id] elem = mesh.outputs.getmesh().ElementById(elem_num) node_index = elem.NodeIds.IndexOf(nodeId) stress_y = sy_field_corner_mid.GetEntityDataById(elem_num)[node_index] print 'stress at element',mesh.outputs.getmesh().ElementIds[id],'and node',nodeId,'is',stress_y
2
