I have some 3D geometry I've constructed in pymapdl and I'm trying to get the nearest node to the coordinates (X, Y, Z). I understand in APDL you would use the N=NODE(X, Y, Z) command as a shortcut for the *GET command.
PyMAPDL does not have an equivalent for this (Yet), so I'm trying to write the explicit get command out using mapdl.get. The APDL command I have so far is as follows:
*GET,_,NODE,N,LOC,0, 0.6, -0.1
I'm just trying to store the data in a blank parameter, hence the _. I'm more interested in what's returned. However at the moment it's throwing an error:
ansys.mapdl.core.errors.MapdlRuntimeError: *** ERROR *** CP = 1.656 TIME= 11:02:53
Unknown label in field 6 ( 0 ) of *GET command.
Line= *GET,_,NODE,N,LOC,0,0.6,-0.1
The *GET command is ignored.
What am I doing wrong? according to the documentation, what I've done so far should work.
EDIT:
using a non-underscore param name did not work either:
ansys.mapdl.core.errors.MapdlRuntimeError: *** ERROR *** CP = 1.500 TIME= 11:24:45
Line= *GET,N,NODE,N,LOC,0,0.6,-0.1
EDIT 2:
This did not work either
ansys.mapdl.core.errors.MapdlRuntimeError: *** ERROR *** CP = 1.578 TIME= 12:00:27
Line= *GET,MYPARAM,NODE,N,LOC,0,0.6,-0.1
