Windows Form deactivates Space Claim interface
I have an C# addin for Space Claim with a Windows Form interface. The user is then asked to select a SPEOS object and press Ok but this requires being able to interact with the interface.
Is there any way I can activate SC interaction behind the form so I can select the object.
Have you found a solution for this? I have done this using an ACT app that launched a WinForms UI and interacts with the Spaceclaim window. I think it would be similar for an AddIn as well. @SeanPatterson
10 -
Thanks @Rajesh Kumar Meena . Yes a solution was found. This unlocked the background : { Window window = Window.ActiveWindow; DocObject sceneSpace = window.Scene.Root; var dialog = new UI_Extensions.ImportPointCloud(); dialog.Show(); }
8
