How do I retrieve Von-Mises stress of nodes in a Named Selection using DPF-Core?
Ayush Kumar
Member, Moderator, Employee Posts: 482
I am using DPF-Core outside WB and there using CPython to retrieve Data from an RST of Harmonic analysis. The RST file contains a named-selection "MYNAMEDSELECTION" (a set of nodes). How do I retrieve the von-mises for each node at each frequency?
import os from ansys.dpf import core from ansys.dpf.core import operators as ops rst_file = os.path.join(r"\Path\to\my\rst\file") model = core.Model(rst_file) # Print solution object print(model) # Print available named selections print('Named selections in model:', model.metadata.available_named_selections) # Get number of result sets tf = model.metadata.time_freq_support print('Number of solution sets:', tf.n_sets) # Restrict data to a specific named selection ns_operator = ops.scoping.on_named_selection() ns_operator.inputs.data_sources.connect(model) ns_operator.inputs.named_selection_name.connect('MYNAMEDSELECTION') # Get node numbers for nodes in named selection mesh_data = ns_operator.outputs.mesh_scoping.get_data() print(mesh_data.ids) # Extract data on the named selection equivalent_stress = ops.result.stress_von_mises(data_sources=model) # Create list for result sets freq_ids = list(range(1, model.metadata.time_freq_support.n_sets+1)) # Restrict scoping to named selection equivalent_stress.inputs.mesh_scoping.connect(ns_operator.outputs.mesh_scoping) equivalent_stress.inputs.time_scoping.connect(freq_ids) fields = equivalent_stress.outputs.fields_container.get_data() for field in fields: print(field.data)
