How do I get real and imaginary stress tensor for a harmonic analysis using DPF-Core?
Ayush Kumar
Member, Moderator, Employee Posts: 483
I am using DPF-Core (PyAnsys) via an IDE (Integrated Development Environment eg. Visual Studio Code) and using PyDPF to retrieve Data from an RST file of a Harmonic analysis. The RST file contains a named-selection "NODE" (a set of nodes). How do I retrieve the stress-tensor (real and imaginary part) for each node at each frequency?
from ansys.dpf import core as dpf from ansys.dpf.core import operators as ops model = dpf.Model(r"\Path\to\my\file.rst") print(model) tf = model.metadata.time_freq_support print('Number of solution sets', tf.n_sets) stress = ops.result.stress(data_sources=model) freq_ids = list(range(1, model.metadata.time_freq_support.n_sets+1)) print(model.metadata.available_named_selections) ns_operator = dpf.operators.scoping.on_named_selection() ns_operator.inputs.named_selection_name.connect('NODE') ns_operator.inputs.data_sources.connect(model) stress.inputs.mesh_scoping.connect(ns_operator.outputs.mesh_scoping) stress.inputs.time_scoping.connect(freq_ids) stress.inputs.requested_location.connect("Nodal") fields = stress.outputs.fields_container.get_data() for freq_id in freq_ids: print("REAL - %s" % fields.get_field_by_time_id(freq_id).data) print("IMAG - %s" % fields.get_imaginary_field(freq_id).data)
In case you want to retrieve this data in Mechanical,
mech_dpf
must be used, the following code will give the same output in Mechanical Scripting Console.NOTE: Please set Mechanical analysis system index in line number 6. This code assumes the first analysis to be Harmonic and retrieves data from that analysis.
import mech_dpf mech_dpf.setExtAPI(ExtAPI) import Ans.DataProcessing as dpf dpf.DataProcessingCore.LoadLibrary("math",r"C:\Program Files\ANSYS Inc\v212\aisol\bin\winx64\Ans.Dpf.Math.dll") ds = mech_dpf.GetDataSources(0) timeProvider = dpf.operators.metadata.time_freq_provider() timeProvider.inputs.data_sources.Connect(ds) freqs = timeProvider.outputs.time_freq_support.GetData() numSets = freqs.NumberSets ids = [index + 1 for index in range(numSets)] freq_scoping = dpf.Scoping() freq_scoping.Ids = ids ns_op = dpf.Operator("scoping_provider_by_ns") ns_op.Connect(1, "NODE") ns_op.Connect(4, ds) #Stress Y op_sy = dpf.Operator("S") op_sy.Connect(0, freq_scoping) op_sy.Connect(1, ns_op) op_sy.Connect(4, ds) op_sy.Connect(9, "Nodal") for id in ids: print "REAL - %s " % op_sy.GetOutputAsFieldsContainer(0).GetFieldByTimeId(id).Data print "IMAG - %s " % op_sy.GetOutputAsFieldsContainer(0).GetImaginaryField(id).Data
2
