Extract and plot BFE temperature from result file
Pernelle Marone-Hitz
Member, Moderator, Employee Posts: 873
Either DPF-Post or DPF-Post can be used for that. The script below can be adapted and illustrates both methods:
# Get started import os from ansys.dpf import post from ansys.dpf import core # Use DPF-Post to import .rst file and check data that is contained rst_file = os.path.join(r'C:\Users\','file.rst') solution = post.load_solution(rst_file) print(solution) # Get and plot BFE temperature using DPF-Post bfe_post = solution.structural_temperature() bfe_post_scalar = bfe_post.scalar bfe_post_scalar.plot_contour(show_edges = True) # Use DPF-Core to do the same model = core.Model(rst_file) results = model.results print(results) bfe_core = results.structural_temperature() bfe_field = bfe_core.outputs.fields_container() bfe_nodal_field = bfe_field[0].to_nodal() #the elemental nodal field needs to be converted to an elemental or nodal field to be plotted mesh = model.metadata.meshed_region mesh.plot(bfe_nodal_field) bfe_data = bfe_field[0].data
4
