How do I retrieve NMISC results for APDL hydrostatic elements (HSFLD242) with DPF?
Ayush Kumar
Ayush Kumar Member, Moderator, Employee Posts: 483
How do I retrieve NMISC results for APDL hydrostatic elements (HSFLD242) with DPF in Mechanical?
enter image description here
  • Ayush Kumar
    You can use the following code.
    Note
    1. This code uses all the HSFLD242 elements in the named selection "HFL". As HSFLD242 are created by the solver, one needs to create APDL component name "HFL" using APDL Snippet (not via Mechanical).
    2. This code uses time-scoping for 4 time-steps, please adjust as per your model.
    import mech_dpf
    mech_dpf.setExtAPI(ExtAPI)
    dpf.DataProcessingCore.LoadLibrary("math", r"C:\Program Files\ANSYS Inc\v211\aisol\bin\winx64\Ans.Dpf.Math.dll")
    ds = mech_dpf.GetDataSources(0)
    time_freq = dpf.operators.metadata.time_freq_provider()
    time_freq.inputs.data_sources.Connect(ds)
    hfl_elements = dpf.Operator("scoping_provider_by_ns")
    hfl_elements.Connect(0, "Elemental")
    hfl_elements.Connect(1, "HFL")
    hfl_elements.Connect(4, ds)
    # Time Scoping
    time_scoping = dpf.data.Scoping()
    time_scoping.Ids = [1, 2, 3, 4]
    # Density NMISC1
    density = dpf.Operator("mapdl::nmisc")
    density.Connect(0, time_scoping)
    density.Connect(1, hfl_elements.GetOutputAsScoping(0))
    density.Connect(4, ds)
    # Please use the NMISC number as a second argument here
    density.Connect(10, 1)
    # TVOL NMISC3
    tvol = dpf.Operator("mapdl::nmisc")
    tvol.Connect(0, time_scoping)
    tvol.Connect(1, hfl_elements.GetOutputAsScoping(0))
    tvol.Connect(4, ds)
    tvol.Connect(10, 3)
    # Density Results for 1st time step
    print density.GetOutputAsFieldsContainer(0)[0].Data
    # TVOL Results for 4th time step
    print tvol.GetOutputAsFieldsContainer(0)[3].Data
