How can I link Analysis System Index in Mechanical to it's corresponding System Index on the Project
Ayush Kumar
How can I link Analysis System Index in Mechanical to it's corresponding System Index on the Project page?
For multiple systems / mechanical sessions of the project page the SYS- is incremented by 1 each time a system is created, based on the time is created. How do I get the SYS- and Analysis index mapping in Mechanical Session.
enter image description here
  • Ayush Kumar
    I don't think there is a direct link between the SYS- and Analysis index from an analysis in Mechanical, because SYS - IDs increment by 1 each time a system is created, SYS- are given to systems in the order of their creation time (SYS, SYS-1, SYS-2…), but the indexes start from zero for every Mechanical session (as shown in the screenshot). One can however, use the result file path to build a workaround.
    The following code will give a dictionary - SYSTEM_ANALYSIS_LINK_DICT, which contains the mapping of SYS-ID with the analysis index.
    Note: Please change "file.rst" in the regex expression as per analysis type.
    SYSTEM_ANALYSIS_LINK_DICT = {}
    import re
    my_regex_expression = r"(.*)\MECH\file.rst"
    for index, analysis in enumerate(ExtAPI.DataModel.AnalysisList):
        system_directory = re.search(my_regex_expression, analysis.Solution.ResultFilePath)
        system_string = system_directory.group(1).Split("\")[-1]
        SYSTEM_ANALYSIS_LINK_DICT.update({system_string: index})
  • Vishnu
    You can as well get the WB system name like below
    analysis1 = ExtAPI.DataModel.Project.Model.Analyses[0]
    WBSystemName = analysis1.WorkingDir.split("\")[-3]
