Can you use Granta MI Text Import template to import multiple text files using STK 2.3?
Assuming the text import template is set up to work within Granta MI Import and python STK is being used to automate the process.
Yes you can, the available methods follow the options available within the OneMI Import app, you can import multiple text files and multiple attachments. Here's an example with two data files:
from GRANTA_MIScriptingToolkit import granta as mpy session = mpy.Session('my_server/mi_servicelayer', autologon=True) queue = session.get_async_job_queue() job_request = mpy.TextImportJobRequest('job_name', description='A test job with two files', data_files=['./file_1.txt', './file_2.txt'], template_files=['./template.txt']) job = queue.create_import_job(job_request) #...wait for job to complete
As you mention this relies upon having a valid template file configured to import into a table.
