Export temperatures from a RTH file to a csv file with PyAnsys
Oscar
Member, Employee Posts: 12
from ansys.dpf import core as dpf import numpy as np # please set the result file path to the right path model = dpf.DataSources() model = dpf.Model(r"D:\...\file.rth") time_freq_support = model.metadata.time_freq_support time_1 = list(time_freq_support.time_frequencies.data) t1 = dpf.operators.result.temperature() t1.inputs.data_sources.connect(model) t1.inputs.time_scoping.connect(time_1) temp = np.array(np.append("Time",t1.outputs.fields_container.get_data()[0].scoping.ids)) for i in range(0, len(time_1)): temp = np.vstack([temp,np.append(time_1[i],t1.outputs.fields_container.get_data()[i].data)]) np.savetxt("D:\...\Test.csv", temp, delimiter=",", fmt="%s")
