How to compute time dependent results difference between two nodes and display the results?
Pierre Thieffry
After a nonlinear or transient run, I want to plot a graph that shows (uy@node1 - uy@node2)-(uy@node1 - uy@node2)@reftime. How can I achieve this in Mechanical?
  • Pierre Thieffry
    There are two answers to this question - one in APDL, one with DPF and a Python result.
    While the code looks more complex for an APDL user, the Python results has several benefits:
    • Scoping could be added to select nodes to compare
    • Graph is a native Mechanical object
    • Results are unit dependent
    • Table can be easily copied
    APDL:
    set,last
    sho,png /post26 nsol,2,359,u,y,UY_OD ! Retrieve UY at node 359
    nsol,3,360,u,y,UY_ID ! Retrieve UY at node 360
    add,4,2,3,,UY(OD-ID),,,1,-1 ! Compute UY_OD-UY_ID
    *get,y_assem,vari,4,real,1.0 ! Get refvalue of above difference at time = 1.0
    filldata,5,,,,y_assem ! Create vector with above refvalue
    add,6,4,5,,DELTA,,,1,-1 ! Compute (UY_OD-UY_ID)-refvalue
    prvar,2,3,4,5,6 ! Print all variables
    /xrange,1,30 ! Limit plot range to time from 1. to 30.s
    plvar,6 ! Plot variable 6
    DPF/Python Result
    node1=359
    node2=360
    reftime=1.0
    model=dpf.Model(dataSource)
    all_times=model.TimeFreqSupport.TimeFreqs.Data # Retrieve all time values
    refIndex=all_times.IndexOf(reftime)+1 # Index of reftime
    timeIds=range(refIndex,len(all_times)+1) # List of time steps for time scoping
    nodeSc1=dpf.Scoping([node1],'Nodal') # scoping for uy at node 1
    nodeSc2=dpf.Scoping([node2],'Nodal') # scoping for uy at node 2
    uy1 = dpf.operators.result.displacement_Y(data_sources=dataSource,time_scoping=timeIds,mesh_scoping=nodeSc1) # operator for node 1
    uydiff = dpf.operators.result.displacement_Y(data_sources=dataSource,time_scoping=timeIds,mesh_scoping=nodeSc1) # operator for end result
    uy2 = dpf.operators.result.displacement_Y(data_sources=dataSource,time_scoping=timeIds,mesh_scoping=nodeSc2) # operator for node 1
    for time in timeIds: # Compute uy1-uy2 and store in uydiff
        v1=uy1.outputs.getfields_container().GetFieldByTimeId(time).Data[0]
        v2=uy2.outputs.getfields_container().GetFieldByTimeId(time).Data[0]
        uydiff.outputs.getfields_container().GetFieldByTimeId(time).Data=[v1-v2]
    refval=uydiff.outputs.getfields_container().GetFieldByTimeId(all_times.IndexOf(reftime)+1).Data[0] # Retrieve refvalue at reftime
    uydiff=uydiff-refval # substract from previous results
    with open(r'd:\temp\udiff.txt','w') as f: # write results to text file
        vdiff=uydiff.outputs.getfields_container().GetFieldByTimeId(time).Data[0]
        f.write("{:16.9f}{:16.9f}{:16.9f}{:16.9f}{:16.9f}{:16.9f}\n".format(all_times[time-1],v1,v2,v1-v2,refval,vdiff))
    #Display in Mechanical
    dpf_workflow = dpf.Workflow()
    dpf_workflow.Add(uydiff)
    dpf_workflow.SetOutputContour(uydiff)
    dpf_workflow.Record('wf_id', True)
