How do I perform Load Case combination of principal stresses using DPF (Python Result) in Mechanical?
Example: LC1- LC2
User defined results Solution Combination in Mechanical does a combination on the calculated results eg. Principal or SEQV, which is not the right way. The combination should be done on the stress tensor level and then Principal or SEQV should be calculated based on the new stress tensor. How do I do this using DPF and plot the results as contour on the body in Mechanical?
