How to export the worksheet view (say Force Convergence graph) as an image via ACT in Mechanical?
Rohith Patchigolla
edited November 2024 in Structures
Best Answers
  • Rohith Patchigolla
    Click on Solution Information in Mechanical --> Change Solution Output to Force Convergence --> Toggle Worksheet View --> and run the below script in Mechanical in ACT Console. This would create an image of the Force Convergence plot in D drive.
    enter image description here
    graphics = ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.Worksheet)
    width = graphics.ControlUnknown.Width()
    height = graphics.ControlUnknown.Height()
    Pane = ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.Worksheet)
    Pane.CommandContainer.WindowRect.Left
    initial_x = Pane.CommandContainer.WindowRect.Left
    initial_y = Pane.CommandContainer.WindowRect.Top
    final_x = initial_x + width
    final_y = initial_y + height
    # Take screenshot
    import clr
    import sys
    clr.AddReference("System.Windows.Forms")
    clr.AddReference("System.Drawing")
    from System.Drawing import Bitmap,Graphics,Point,Size
    from System.Windows.Forms import(
        Application,Button,Form,FormWindowState,
        PictureBox,Screen)
    bmp = Bitmap(final_x-initial_x, final_y-initial_y)
    g = Graphics.FromImage(bmp)
    g.CopyFromScreen(initial_x,initial_y, 0, 0, Size((final_x-initial_x), (final_y-initial_y)))
    bmp.Save(r"D:\test.png")
    g.Dispose()
  • Vishnu
    We can add this to automatically navigate to force convergence plots before executing above script:
    Mechanical --> Solution Output to Force Convergence --> Worksheet View
    solution = ExtAPI.DataModel.Project.Model.GetChildren(DataModelObjectCategory.Solution,True)[0]
    solution.SolutionInformation.SolutionOutput = SolutionOutputType.ForceConvergence
    solution.SolutionInformation.Activate()
  • Matthias
    Matthias Member Posts: 35
    10 Comments Name Dropper First Anniversary
    How can the export of the force convergence graph be achieved during a design point update?
    Hello @Matthias , unfortunately the solution in this post is not applicable for batch mode (design point update). For DP study, I would consider using file.gst in the solver directory, which can be plotted in MAPDL gui or, one could use some simple python script with Python Code object (after solve callback) to extract just the 2 columns corresponding to the Force Convergence graph and make a matplot lib curve for example.
