How to add custom properties at the body level in SCDM?
Example:
# Python Script, API Version = V21 from SpaceClaim.Api.V21 import CustomProperty, SimplePropertyDisplay, Application class CustomPropertyDisplay(SimplePropertyDisplay): """This is a property diplay class used to populate the properties window. To use it, you must first register it with the Application: Application.AddPropertyDisplay(...). Once registerd the GetValue method is called on each selection change, and it should return the string to be displayed.""" def __init__(self, category, name): SimplePropertyDisplay.__init__(category,name) def GetValue(self, body): # Make sure the selection is a body if not isinstance(body, IDesignBody): return None # Try to get the "MyCustomProp" attribute from the body (success, value) = body.GetMaster().TryGetTextAttribute("MyCustomProp") return value def SetValue(self, body, value): # Make sure the selection is a body if not isinstance(body, IDesignBody): return None # Update the attribute body.GetMaster().SetTextAttribute("MyCustomProp", value) # All DocObjects allow you set Text and Number attributes. # We will use these attributes to store our custom property for body in GetRootPart().GetAllBodies(): body.GetMaster().SetTextAttribute("MyCustomProp", "This is my description") Application.AddPropertyDisplay(CustomPropertyDisplay("My_custom_properties", "my_title"))
