DPF in Mechanical doesn't run on Linux machine in 2022R1?
Ayush Kumar
Ayush Kumar Member, Moderator, Employee Posts: 495
DPF code doesn't run on Linux machine in 2022R1?
enter image description here
  • Ayush Kumar
    For 2022R1 Ansys’ Linux installation is not shipped with the CS_DataProcessing.dll which the C:\Program Files\ANSYS Inc\v221\aisol\DesignSpace\DSPages\Python mech_dpf.py script adds a reference to, that is the error shown above.
    As a workaround you can copy C:\Program Files\ANSYS Inc\v221\aisol\bin\winx64\ CS_DataProcessing.dll from Windows Ansys installation on the Linux machine and add the reference to the dll in the new path, using the code below. Please make sure to add these lines at the top of your existing code:
    import clr
    clr.AddReferenceToFileAndPath("/Path/to/CS_DataProcessing.dll")
    import mech_dpf
    mech_dpf.setExtAPI(ExtAPI)
    ds = mech_dpf.GetDataSources(1)
    NOTE: Currently for Linux, DPF’s IronPython API is not supported in Mechanical. If you have written some of your code using the IronPython API you will need to convert that to C++ Syntax (but still Python code). Please refer to mech_dpf.help()
