How to extract stress reults from ansys motion result file
Vishnu
Member, Employee Posts: 222
the below code extracts Von-Mises on node 1: Please change the motion path if necessary.
import clr, sys,os sys.path.append(r'C:\Program Files\ANSYS Inc\v221\Motion\bin') clr.AddReference('System.Collections') from System.Collections.Generic import List clr.AddReference('VM.Post.API.OutputReader') from VM.Post.API.OutputReader import * analysis = ExtAPI.DataModel.Project.Model.GetChildren(DataModelObjectCategory.Analysis,True) motion_an = filter(lambda x: x.SolverName == 'ANSYSMotion@ANSYSMotion', analysis)[0] work_dir = motion_an.WorkingDir filePath = os.path.join(work_dir,'file.dfr') outputReader = OutputReader(filePath) parameters = PlotParameters() paths = List[str]() parameters.Target = "Solid/Node/1" paths.Add("Top Stress/VonMises") parameters.Paths = paths results = outputReader.GetCurves(parameters) for plot in results : print("Time ,", plot.Key) for value in plot.Value : print(value)
2
