How to sum damage results by creating your own field using DPF
Vishnu
You can use the similar method to sum or manipulate contour results from multiple result objects.
this example shows how to sum the damage results from 2 damage result objects and plot them using python results
  • Vishnu
    edited January 2023 Answer ✓
    In this example we create our own scalar field and populate the data and id and use the created scalar fields to plot.
    The algorithm is like below:
    Algorithm
    Your sample code will look like below: I am getting damage result objects by name "damage". Please change that line according to your case.
        define_dpf_workflow(analysis)
        analysis = ExtAPI.DataModel.AnalysisByName(ExtAPI.DataModel.AnalysisNames[0])
        import mech_dpf
        # Get IDs of damage object to combine
        damageresults = ExtAPI.DataModel.GetObjectsByName("damage")
        # build set with all nodes
        all_scoped_nodes = []                           # Create List of nodes
        for damageobj in damageresults:
            all_scoped_nodes.extend(damageobj.PlotData.Values[1]) # add nodes from each UDR
        all_scoped_nodes_set = set(all_scoped_nodes)    # create set - eliminate multiple entries
        all_scoped_nodes = list(all_scoped_nodes_set)   # create list from set
        ### Create new results
        #analysis=ExtAPI.DataModel.AnalysisByName('Static Structural')
        # Read mesh in results file
        mesh_op = dpf.operators.mesh.mesh_provider() # operator instanciation
        mesh_op.inputs.data_sources.Connect(dataSource)
        mesh = mesh_op.outputs.mesh.GetData()
        field_list = []
        # go through all values of each damage results and feed them into created field
            # Create Field of necessary size
            numnodes = len(all_scoped_nodes)                                  # number of nodes
            field = dpf.FieldsFactory.CreateScalarField(numnodes)    # create field with size
            field.MeshedRegionSupport = mesh                         # attach mesh
            field.ScopingIds = all_scoped_nodes                      # give list of nodes
            field.Data = [0. for i in range(0,len(all_scoped_nodes))]# fill field with zeros
            node_scope_udr = damageobj.PlotData.Values[1]
            val_udr = damageobj.PlotData.Values[len(damageobj.PlotData.Values)-1]
            for ii in range(0,len(node_scope_udr)):
                index=field.ScopingIds.IndexOf(node_scope_udr[ii])         # get index of node in created field
                field.UpdateEntityDataByEntityIndex(index,[val_udr[ii]])
            field_list.append(field)
        sum_field_list = field_list[0]
        for i in range(0,len(field_list)-1,1):
           sum_field_list = dpf.operators.math.add(fieldA=sum_field_list,fieldB=field_list[i+1])
        # Create field operator for plotting
        combined_plot = dpf.operators.utility.forward_field() # operator instanciation
        combined_plot.inputs.field.Connect(sum_field_list)
        ### create plotting workflow
        dpf_workflow = dpf.Workflow()
        dpf_workflow.Add(combined_plot)
        dpf_workflow.SetOutputContour(combined_plot)
        dpf_workflow.Record('wf_id', True)
    Summation of 2 damage results sum of damages
