User has created a name selection on a face, yet wants to extract stress values only at corner nodes. How can he do this?
Not sure this is the cleanest way, but the below code will work. The idea is to collect a list of all corner nodes from the mesh, then intersect a named selection's ids with this list and scope results to this restricted list of nodes
import mech_dpf import Ans.DataProcessing as dpf import Ans.DataProcessing.operators as ops mech_dpf.setExtAPI(ExtAPI) my_data_source = mech_dpf.GetDataSources() ns = ops.scoping.on_named_selection() ns.inputs.data_sources.Connect(my_data_source) ns.inputs.requested_location.Connect("Nodal") ns.inputs.named_selection_name.Connect("FACE") model=dpf.Model(my_data_source) model.ReleaseStreams() rst_mesh=model.Mesh corner_nodes=[] # Parse all nodes to find corner node ids all_elems=rst_mesh.Elements for el in all_elems: corner_nodes.extend(el.CornerNodeIds) # Remove duplicates corner_nodes=list(dict.fromkeys(corner_nodes)) # Create node scoping only on corner nodes # intersection of full list of corner_nodes and scoping from above named selection corner_scoping=dpf.Scoping() corner_scoping.Ids=list(set(corner_nodes) & set(ns.outputs.mesh_scoping.GetData().Ids)) # Retrieve whichever result, scoped on corner nodes of interest stress_op = ops.result.stress_X() stress_op.inputs.data_sources.Connect(my_data_source) stress_op.inputs.mesh_scoping.Connect(corner_scoping) my_stress = stress_op.outputs.fields_container.GetData()[0] for id in my_stress.ScopingIds: print(id,my_stress.GetEntityDataById(id)[0])
