How can I insert a contact tool and contact pressure result, find the maximum value and the node numbers that have this max value?
Adapt the following code:
# Create contact tool and contact pressure model = ExtAPI.DataModel.Project.Model solution = model.Analyses[0].Solution contact_tool = solution.AddContactTool() contact_pressure = contact_tool.AddPressure() contact_pressure.EvaluateAllResults() contact_pressure_max = contact_pressure.Maximum # Extract data from plot plot_data = contact_pressure.PlotData nodes = plot_data ['Node'] result_value = plot_data ['Values'] # Handle unit conversion import units currentLengthUnit=ExtAPI.DataModel.CurrentUnitFromQuantityName('Stress') scale_factor=units.ConvertUnit(1.,currentLengthUnit,result_value.Unit) for index in range(len(nodes)): if result_value[index] == contact_pressure_max.Value*scale_factor: print(nodes[index])
