Volume and mass of elements above a result threshold
Pernelle Marone-Hitz
Pernelle Marone-Hitz Member, Moderator, Employee Posts: 873
Using ACT scripting, how can I find the elements for which the average stress is above a specific value and sum the volume of these elements, and find the summed mass of these elements ?
    The following code can be adapted. Please note that this simplified example considers that only one material is used in the model.
    # Define threshold
    threshold = Quantity('100 [MPa]')
    # init
    summed_volume = 0
    summed_mass = 0
    # Insert result
    eqv_stress = ExtAPI.DataModel.Project.Model.Analyses[0].Solution.AddEquivalentStress()
    eqv_stress.DisplayOption = ResultAveragingType.ElementalMean
    eqv_stress.EvaluateAllResults()
    # Extract data from plot
    plot_data = eqv_stress.PlotData
    elements = plot_data ['Element']
    result_value = plot_data ['Values']
    # Mesh data
    mesh_data = ExtAPI.DataModel.Project.Model.Analyses[0].MeshData
    # Handle unit conversion
    import units
    result_unit = result_value.Unit
    mesh_unit = mesh_data.Unit
    scale_factor_stress = units.ConvertUnit(1.,result_unit,threshold.Unit)
    for index in range(len(elements)):
      if result_value[index]*scale_factor_stress > threshold.Value:
        summed_volume = summed_volume + mesh_data.ElementById(elements[index]).Volume
    summed_volume = Quantity(str(summed_volume) + '[' + mesh_unit + '^3]')
    print('Summed volume is: ' + str(summed_volume))
    # Get material
    # WARNING this code demo only grabs the material of the first body in the tree and assumes all elements above use this material
    import materials
    mat = ExtAPI.DataModel.Project.Model.Materials.Children[0]
    # get engineering data material properties for this material
    matED = mat.GetEngineeringDataMaterial()
    density = materials.GetMaterialPropertyByName(matED,"Density")['Density']
    # Get mass
    summed_mass = summed_volume.Value*density[1]
    print('Summed mass is: ' +str(summed_mass) + ' [kg]')
  • Lorenz
    Lorenz Member Posts: 6
    Photogenic Name Dropper First Comment
    Hi Pernelle
    You are using *.PlotData in above example to get the stresses. Can we also use dpf?
    Regards
    Lorenz
    Hi @Lorenz , yes, DPF could also be used for that purpose. I think I had initially written that script before DPF was released.
  • Jim Kosloski
    Jim Kosloski Member, Employee Posts: 31
    I need to do this but more accurately than on an element by element basis. Give the nodal (or integration point stresses) can we determine the volume of that element that is above the threshold value?
    @Jim Kosloski This should be doable but only through MAPDL / PyMAPDL I think
