How do I find the time varying center of gravity location of my body using DPF ?
The COG of a body might vary with time as the body deforms and you might be interested in knowing how to compute the time varying COG.
the example also highlights on how you can create your own mesh with DPF.
Example uses SOLID elements in this case to demonstrate and used DPF inside mechanical
NOTE : You will need 2024R1 version of Ansys for this to work
#Inputs time_point = 3 named_selection_string = "MYBODY" #Import statements import mech_dpf import Ans.DataProcessing as dpf # Result Data analysis1 = ExtAPI.DataModel.Project.Model.Analyses[0] dataSource = dpf.DataSources(analysis1.Solution.ResultFilePath) # Get mesh my_model = dpf.Model(analysis1.Solution.ResultFilePath) my_mesh = my_model.Mesh # Time list timelist = dpf.operators.metadata.time_freq_provider(data_sources=dataSource).outputs.gettime_freq_support().TimeFreqs.Data time_index_list = [int(timelist.IndexOf(time_point)+1)] # Named Selection Mesh scoping ns_op = dpf.operators.scoping.on_named_selection(requested_location='Elemental', named_selection_name=named_selection_string, data_sources=dataSource) mymeshscoping = ns_op.outputs.getmesh_scoping() # Get Deformation u = dpf.operators.result.displacement(time_scoping=time_index_list, data_sources=dataSource) disp_field = u.outputs.fields_container.GetData()[0] # Create my own mesh created_mesh = dpf.MeshedRegion(my_mesh.Nodes.Count, 0) for node in my_mesh.Nodes: displacement = disp_field.GetEntityDataById(node.Id) created_mesh.AddNode(node.Id, [node.X + displacement[0], node.Y + displacement[1], node.Z + displacement[2]]) createdmesh_nodeids = created_mesh.NodeIds for elem in my_mesh.Elements: created_mesh.AddSolidElement(elem.Id, list(map(lambda x: createdmesh_nodeids.IndexOf(x), elem.CornerNodeIds))) # Centroids centroids = dpf.Operator("compute_element_centroids") centroids.Connect(1, mymeshscoping) centroids.Connect(7, created_mesh) centroid = centroids.GetOutputAsField(0) def compute_elemental_mass(): # List to store elemental densities all_mats = [] mats = my_mesh.GetPropertyField("mat") mat_prop = my_model.CreateOperator("mapdl_material_properties") mat_prop.inputs.materials.Connect(mats) mat_prop.inputs.properties_name.Connect("DENS") mat_field = mat_prop.outputs.properties_value.GetData()[0] for eid in my_mesh.ElementIds: mat_id = mats.GetEntityDataById(eid) density = mat_field.GetEntityDataById(mat_id[0]) all_mats.append(density[0]) # Create Density Field density = dpf.FieldsFactory.CreateScalarField(numEntities=my_mesh.ElementCount,location=dpf.locations.elemental) density.ScopingIds = my_mesh.ElementIds density.Data = all_mats # Element volume el_vol = dpf.operators.geo.elements_volume(mesh=my_mesh) # Calculate elemental mass (density * volume) elemental_mass = dpf.operators.math.generalized_inner_product(fieldA=el_vol, fieldB=density).outputs.getfield() return elemental_mass elemental_mass = compute_elemental_mass() #Function to calculate mass-weighted centroid def calculate_mass_weighted_centroid(centroid, mass): num_points = centroid.ElementaryDataCount # Extract x, y, z components x_comp = dpf.operators.logic.component_selector(field=centroid, component_number=0).outputs.getfield().Data y_comp = dpf.operators.logic.component_selector(field=centroid, component_number=1).outputs.getfield().Data z_comp = dpf.operators.logic.component_selector(field=centroid, component_number=2).outputs.getfield().Data # Calculate mass-weighted sums sum_mass = sum(mass.Data) sum_x = sum(x * m for x, m in zip(x_comp, elemental_mass.Data)) sum_y = sum(y * m for y, m in zip(y_comp, elemental_mass.Data)) sum_z = sum(z * m for z, m in zip(z_comp, elemental_mass.Data)) # Calculate mass-weighted centroid if sum_mass > 0: centroid_x = sum_x / sum_mass centroid_y = sum_y / sum_mass centroid_z = sum_z / sum_mass else: raise ValueError("Total mass is zero or negative") return (centroid_x, centroid_y, centroid_z) #Print mass-weighted centroid print(calculate_mass_weighted_centroid(centroid,elemental_mass))
Hi @Vishnu, thank you for this example!
One remark though:
This is tagged as "PyDPF", yet as it is using the API for use within Mechanical, I am afraid this will create confusion for people trying to use this with PyDPF-Core/Post. Is there a better suited tag available? Or maybe we should create one specific for use of DPF from within Mechanical, be it in Python.
3 -
I think so too we may need to create one for DPF from within Mechanical
Hey! I added the DPF tag to your post! Also can you confirm that COG = "Centre of Gravity"? I don't think you state it anywhere.
