How to get time, load step and max sub step at a given load step information from dpf?
Vishnu
Member, Employee Posts: 222
import mech_dpf import Ans.DataProcessing as dpf #Model #Result Data analysis1 = ExtAPI.DataModel.Project.Model.Analyses[0] dataSource = dpf.DataSources(analysis1.Solution.ResultFilePath) my_model = dpf.Model(analysis1.Solution.ResultFilePath) timefreqsupport = my_model.TimeFreqSupport print 'loadsteps are-->',list(dpf.operators.metadata.time_freq_provider(data_sources=dataSource).outputs.time_freq_support.GetData().TimeFreqs.ScopingIds) print 'Time list is-->',list(dpf.operators.metadata.time_freq_provider(data_sources=dataSource).outputs.time_freq_support.GetData().TimeFreqs.Data) print 'Max Substep for load step 3 is-->',dpf.operators.metadata.time_freq_provider(data_sources=dataSource).outputs.time_freq_support.GetData().TimeFreqs.GetEntityDataById(3).Count
