How to run a Workbench script in headless in mode?
Landon Mitchell Kanner
Member, Employee, GitHub-issue-creator Posts: 353
I have a Workbench script that I would like to run fully headless.
This command line will start Workbench (version 2022 R2) in headless mode and run the script RunWB.wbjn, which resides in the current working directory (%cd%) of the Command Prompt:
"%AWP_ROOT212%\Framework\bin\Win64\runwb2.exe" -B -R "%cd%\RunWB.wbjn" -nowindow
Note that -nowindow is an undocumented command, which are outside of any Quality Assurance (QA) programs and may not be forward compatible. Use at your own risk. You can get a list of arguments using ProcessExplorer for any executable. Refer to this.
Documented arguments for runwb2.exe:
-A addinsfile: Use addins file 'addinsfile' -B: Run in batch -C configfile: Use configration 'configfile' -D dataFile: Import an application data file -E statement: Execute a journal statement at startup. May be repeated -F WBProject: Open a Workbench project file (*.wbpj) -I: Run interactively -L language: Show UI in 'language' -R replayfile: Use replay file 'replay' -W workspace: Start UI with specified workspace -X: Run interactively & exit upon journal replay end
1
