How do I use the Vanilla Rich text editor?
James Derrick
James Derrick Administrator, Employee Posts: 248
First Anniversary Solution Developer Community of Practice Member Ansys Employee 5 Up Votes
admin
edited August 2023 in Announcements
This forum is a Vanilla forum, and we USED TO use the Vanilla "rich editor*", however, it can be a little unclear how to use it initially. How do you use it?
*We have moved to using Markdown and a simple ribbon.
  • Landon Mitchell Kanner
    Landon Mitchell Kanner Member, Employee Posts: 200
    First Answer First Comment 5 Likes First Anniversary
    edited December 2022
    Example to change text to Code Block:
    @James Derrick , How did you get your GIFs to display properly? I have tried several methods, but they appear small and/or do not animate.
  • James Derrick
    admin
    @Landon Mitchell Kanner All fixed! It was a settings issue on the backend.
  • James Derrick
    admin
    NOTE
    We have recently switched away from the rich editor to the "Advanced Editor". This provides a simple editing ribbon above posts and should be more intuitive.
    Additionally, pure markdown can be used. The comments above are about the Rich Editor Only!
