How do I export Tabular data of selected result objects to a CSV?
The following code can be saved as a Button. Select all the result objects, which you want exported in a CSV file. On being clicked a "data.csv" file is written in the User Files Directory of the project.
import os import wbjn userfilesdir = wbjn.ExecuteCommand(ExtAPI,"""returnValue(GetUserFilesDirectory())""") file_name = os.path.join(userfilesdir, "data.csv") file_handle = open(file_name, "w") time_unit = ExtAPI.DataModel.CurrentUnitFromQuantityName("Time") temp_unit = ExtAPI.DataModel.CurrentUnitFromQuantityName("Temperature") for index, temp in enumerate(Tree.ActiveObjects): temp.Activate() paneTabular=ExtAPI.UserInterface.GetPane(MechanicalPanelEnum.TabularData) control = paneTabular.ControlUnknown file_handle.write("Result Object %s - %s\n" % (index, temp.Name)) file_handle.write("Time[{0}];Minimum[{1}];Maximum[{1}];Average[{1}]\n".format(time_unit, temp_unit)) for row in range(2, control.RowsCount+1): for col in range(2, control.ColumnsCount+1): cellText = control.cell(row, col).Text file_handle.write("%s;" % cellText) file_handle.write("\n") file_handle.close()
Please refer to Ansys Help link on How to create user-defined button in Mechanical?
The paneTabular method doesn't work on linux, at least it didn't for me and it's not supported.
Supported and slower method:
import wbjn, os ufDir=wbjn.ExecuteCommand(ExtAPI,"returnValue(GetUserFilesDirectory())") analyses = ExtAPI.DataModel.Project.Model.Analyses print(ufDir) with Transaction():# after 2020R1 (suspendClicks=True) to accelerate the process for analysis in analyses: time_steps =analysis.GetResultsData().ListTimeFreq for result in analysis.Solution.Children: if 'Results' in result.GetType().ToString(): result.By = SetDriverStyle.Time t_unit = result.Time.Unit first = True saveName = os.path.join(ufDir,analysis.Name + '_' + result.Name + '.csv') with open(saveName,'w') as f: for time in time_steps: result.DisplayTime = Quantity(time,t_unit) result.EvaluateAllResults() Min = result.Minimum Max = result.Maximum Ave = result.Average if first: f.write('time, ' + Min.Unit + ', ' + Max.Unit + ', ' + Ave.Unit + '\n' ) first = False f.write(str(time) + ', ' + str(Min.Value) + ', ' + str(Max.Value) + ', ' + str(Ave.Value) + '\n' )
@M
I also experienced the same error on Linux
doesn't work.
Did you find an improved way?
The suggested code is super slow.
