How can I compute a curvilinear abscissa along a non-straight path in IronPython?
Pierre Thieffry
Member, Moderator, Employee Posts: 111
Say I have an edge or set of edges in Mechanical which are not straight . How can I derive an abscissa to plot some quantity against?
There would be many libraries available in C-Python to achieve this. I'm proposing the following simple code. For a set of nodes, nodes_coords would be a dictionary whose keys are the node numbers and the values are a list of three coordinates [x,y,z]
def findClosestNode(ref_coord,node_coords): mindist=1e31 minnode=-1 for nd,coord in node_coords.items(): dist=(ref_coord[0]-coord[0])**2+(ref_coord[1]-coord[1])**2+(ref_coord[2]-coord[2])**2 if dist<mindist: mindist=dist minnode=nd return minnode,mindist def getCurvilinearAbscissa(node_coords): local_node_coords=node_coords curv_absc=[] distances={} # find node with lowest X xmin=1e31 for nd,coord in node_coords.items(): if xmin>coord[0]: xmin=coord[0] ndmin=nd dist_idx=0 ref_coord=node_coords[ndmin] distances[dist_idx]=[ndmin,0.] dist_idx+=1 del local_node_coords[ndmin] # Now compute distance between nodes while len(local_node_coords.keys())>0: next_node,dist=findClosestNode(ref_coord,local_node_coords) distances[dist_idx]=[next_node,math.sqrt(dist)] ref_coord=node_coords[next_node] del local_node_coords[next_node] dist_idx+=1 curv_absc=[[distances[0][0],0.]] for i in range(1,max(distances.keys())+1): curv_absc.append([distances[i][0],curv_absc[-1][1]+distances[i][1]]) return curv_absc mesh=ExtAPI.DataModel.MeshDataByName(ExtAPI.DataModel.MeshDataNames[0]) for i in my_node_ids: nd=mesh.NodeById(i) node_coords[i]=[nd.X,nd.Y,nd.Z] curv_abs=getCurvilinearAbscissa(node_coords)
