How can I export the elements of the deformed geometry?
itxasne
itxasne Member Posts: 2
edited June 21 in Structures
Hi, I have used the following snippet for exporting the elements and write the in a txt file but was unsuscessful, if anyone could help.
allsel ! Select all entities of the model.
*GET, E_COUNT, ELEM,0,COUNT
/PREP7
my_elements = E_COUNT
*cfopen, element_data_file,txt        !Create a txt file called "node_data_file"​
*do,i,1,num_elements,1          ! Loop over each node​
    num_nodes = ETABLE(ELEM, i, NODE, 0)​
   node_id_1 = ETABLE(ELEM, elem_num, NODE, 1)​
   node_id_2 = ETABLE(ELEM, elem_num, NODE, 2)​
   node_id_3 = ETABLE(ELEM, elem_num, NODE, 3)​
   node_id_4 = ETABLE(ELEM, elem_num, NODE, 4)​
   *vwrite, node_id_1,node_id_2,node_id_3, node_id_4              ! Write out these values​
    (4F16.5)   ​
*enddo​
*CFCLOS                            ! Close file​
  • Pierre Thieffry
    Pierre Thieffry Member, Moderator, Employee Posts: 87
    25 Answers 10 Comments 25 Likes First Anniversary
    Not sure I understand what you are trying to do. Could you please elaborate on your goal?
