pyFluent - Returns zone names while meshing
Alex
Alex Member Posts: 2
edited June 2023 in Fluids
Hi!
I have been trying to construct a 'smart' meshing process which would query label/zone names and issue surface refinement depending on said names. Is there a command whose output would be all the zone names in a table or something?
Same question at but for the solver instead of the mesher.
Thanks you for your time!
Alex,
Skeleton code to help with understanding:
For name in zone_table:
if name contains "_ref03":
"meshing.workflow.TaskObject['Add Local Sizing'].Arguments.set_state({r'AddChild': r'yes',r'BOIFaceLabelList': [name],r'BOISize': ,})"
  • tletutour
    tletutour Member, Employee Posts: 1
    Ansys Employee First Comment
    I don't know if this could help you ( I was trying to retrieve id/name correspondance for volumic zones) but there is an active_list command in fluent which returns zone names and their id. There is no pythonic way to get that resultthat I know of so you would need to record python stdout input like so :
    from contextlib import redirect_stdout
    meshing = pyfluent.launch_fluent(mode="meshing")
    meshing.tui.file.read_mesh(filename)
    f = io.StringIO()
    with redirect_stdout(f):
        meshing.tui.mesh.manage.active_list()
    # s now contains the output of the active_list command
    s = f.getvalue()
  • Alex
    edited May 2023
    All,
    The command below is working fine. Make sure to use the command from a python file (see code below). Do not use it from Fluent command line as it seems that the object "meshing" would be a bit different then.
    Hope this helps & thanks everyone for your help,
    Alex,
    SOLUTION
    meshing.scheme_eval.scheme_eval('(tgapi-util-convert-zone-ids-to-name-strings (get-face-zones-of-filter "*let*"))')
    Code that successfully tested the command
    import ansys.fluent.core as pyfluent
    meshing = pyfluent.launch_fluent(precision="double", processor_count=8, mode="meshing", show_gui=False)
    meshing.workflow.InitializeWorkflow(WorkflowType=r'Watertight Geometry')
    meshing.workflow.TaskObject['Import Geometry'].Arguments.set_state({r'FileName': r'C:/yourPath/yourFile.scdoc',"LengthUnit": "mm",})
    meshing.workflow.TaskObject['Import Geometry'].Execute()
    test = meshing.scheme_eval.scheme_eval('(tgapi-util-convert-zone-ids-to-name-strings (get-face-zones-of-filter "*let*"))')
    print(test)
    ['origin-inlet-nozzle', 'origin-outlet-duct', 'origin-wall-inlet-duct']
    My Environment just for information:
    Python3.10
    Pycharm
    pip list ansys-fluent-core
    Package Version
    ansys-api-fluent 0.3.5
    ansys-api-platform-instancemanagement 1.0.0b3
    ansys-fluent-core 0.12.3
    ansys-fluent-parametric 0.6.1
    ansys-fluent-visualization 0.6.0
    ansys-platform-instancemanagement 1.0.3
    appdirs 1.4.4
    certifi 2022.12.7
    charset-normalizer 3.0.1
    contourpy 1.0.7
    cycler 0.11.0
    fonttools 4.38.0
    googleapis-common-protos 1.58.0
    grpcio 1.51.1
    h5py 3.8.0
    idna 3.4
    imageio 2.25.1
    importlib-metadata 6.0.0
    kiwisolver 1.4.4
    matplotlib 3.7.0
    numpy 1.24.2
    packaging 23.0
    pandas 1.5.3
    Pillow 9.4.0
    pip 23.1.2
    pooch 1.6.0
    protobuf 3.20.3
    protoc-gen-swagger 0.1.0
    pyparsing 3.0.9
    PySide6 6.4.2
    PySide6-Addons 6.4.2
    PySide6-Essentials 6.4.2
    python-dateutil 2.8.2
    pytz 2022.7.1
    pyvista 0.38.2
    pyvistaqt 0.9.1
    QtPy 2.3.0
    requests 2.28.2
    scooby 0.7.1
    setuptools 65.5.0
    shiboken6 6.4.2
    six 1.16.0
    urllib3 1.26.14
    vtk 9.2.6
    zipp 3.14.0
