Hi everyone!
I'm working on system coupling (Fluent and Mechanical at the moment) with pySystemCoupling. I managed to write a script that uses .scp, .dat and .cas files generated by the 'System Coupling' Component System in Workbench. (see the attached picture)
My objective is to eliminate the need to work with Workbench. I was able to write a .scp file using pyFluent but I find it difficult to do the same with Mechanical.
Your comments and suggestions will be greatly appreciated! 😁
