How to extract rotational displacements on a static analysis ?
Pernelle Marone-Hitz
Member, Moderator, Employee Posts: 900
How can I extract the rotational displacement values from the result file of a static structural analysis using PyDPF?
raw_displacement
operator can be used for that purpose. Please note that the data contained inraw_displacement
will depend on the types of elements used, the type of analysis, whether the model is 2D or 3D, etc.Below is an example:
import ansys.dpf.core as dpf import numpy as np rstfile = r'D:/nodal_solution/file.rst' datfile = r'D:/nodal_solution/ds.dat' substep = 4 # create the DataSource ds = dpf.DataSources() ds.set_result_file_path(rstfile, key="rst") ds.add_file_path(datfile, key="dat") # instantiate a Model model = dpf.Model(data_sources=ds) print(model) # define a time_scoping on substep 4 time_scoping = dpf.time_freq_scoping_factory.scoping_by_step_and_substep_from_model( load_step_id=1, subset_id=substep, model=model ) # extract the raw displacements displacement_fc = dpf.operators.result.raw_displacement( time_scoping=time_scoping, data_sources=model, ).eval() print(displacement_fc) # extract the field from the fields_container disp_field = displacement_fc[0] print(disp_field) # one can access the field's underlying numpy.ndarray using ".data" print(disp_field.data) # save to csv np.savetxt( 'displacement2_pydpf-core.csv', X=disp_field.data, delimiter=',', comments='', fmt='%.18e', header="UX, UY, UZ, RX, RY, RZ" ) # optional: extract the rotational dofs from the field rotational_disp = dpf.operators.logic.component_selector( field=disp_field, component_number=[3, 4, 5] ).eval() print(rotational_disp)
